CME and Unified Applications
Ojasvi Bansal
Hello Experts,
I have a quick question: Is there anyway of finding out what Unified Applications/clients/servers can be used with CME on ISR?
Few of the popular applications are:
Cisco Unified Presence
Cisco Unified MeetingPlace
Cisco Unified Personal Communicator
Cisco Unified Mobile Communicator
Thanks and Regards
OJ
Jaime Valencia
Yes, you need to review the requirements for any app you're interested in and they will show what are the requirements, CME and/or CUCM and version compatibility.
If you don't see CME there, then it's not supported.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
Jaime Valencia
java
java
Thanks Java,
Isn't there a one sheet document that outlines compatibility matrix? That would be pretty cool and time saver.
thanks for your response
OJ
That only exists for CUCM, and still in many cases, you're referred to the documentation from the other product since that info is contained within the RNs or a document which outlines requirements.
java
java
