CME PIN Code Dialing
Lucky Mashau
HI
I Have a requirement from my client  to use a pin code before dialing the number , i got every thing working with the  below configs, my biggest chalange is to
get the fax to work under this configs i have one ATA , currently my fax can receive fax but can't dial out because of the configs below can any suggest a solution to get my fax working with no pin number, i was thinking of using a translation  that will be used when you want to fax but my challange again was  if people start to know that when  the want to fax the Dial 9 and a fax number  the can also use that to their phone.
ephone-template  1
softkeys idle  Redial Login Cfwdall Pickup Gpickup Dnd
telephony-service
after-hours block pattern 1 0
after-hours block pattern 2 1
after-hours day Sun 00:00 23:59
after-hours day Mon 00:00 23:59
after-hours day Tue 00:00 23:59
after-hours day Wed 00:00 23:59
after-hours day Thu 00:00 23:59
after-hours day Fri 00:00 23:59
after-hours day Sat 00:00 23:59
create cnf-files version-stamp 7960 Jun 30 2011 09:17:42
ephone-template  1
ephone-dn  1  dual-line
number 7200
pickup-group 1
label CRIME1
name ACII  lucky mashu
allow watch
corlist outgoing call-cell
transfer-mode consult
ephone  1
device-security-mode none
description mashu lucky
mac-address 2893.FEA3.2BEF
ephone-template 1
type 7911
button  1:1
pin 198320
ephone-dn  40  dual-line
number 7040
pickup-group 1
name ACII
allow watch
ephone  11
description FAx Line
mac-address 3037.A616.1868
max-calls-per-button 2
type ata
button  1:40
Use the command "after-hours exempt" under the ATA ephone
Gabriel
Gabriel
i Used the command "after-hours exempt
it works !!!!!!!!!!!!!!!
Show us, because I cant block dialing , show us yor configuration aplay please
Gabriel is right with after-hours exempt
But could you give a try for "after-hour login htpp " which is new for ios 15.0 release
