Communication between phones CUCM and ALCATEL
kingstdz
Hello
i have phone1 alcatel ip in lan1 with ip1 and cisco phone 2 registred ip in CUCM lan 2 via gateway with dialpeer of alcatel patern destination,  how to communicate ALCATEL phone with CISCO Phone.
there is wan between lan 1 and lan 2.
thanks
2 Accepted Solutions
You would need to integrate the two systems with each other via a trunk. These days it is typically done via a SIP trunk and that is facilitated by having an SBC, such as a Cisco router running Cube. Back in the days it was typically done via a PRI connection, again it would include a Cisco router, but this time with a E1/T1 card. Via this trunk the two disparate systems would have the option to communicate with each other.
Response Signature
Less then 30 second spent on a search engine gave me this.
Response Signature
Response Signature
Hello
thanks for your reply
how i can set it from ALCATEL, if you have an example to do it, i will apréciate.
example how to config it from cisco and alcatel.
thanks
Response Signature
hello
thanks Mr Roger Kallberg thats why you are expert thanks a lot
best regards
