08-30-2016 11:42 PM - edited 03-19-2019 11:32 AM
We have a CUCM cluster with 3 Nodes (Version: 10.5.1) and a IM&P cluster with 2 Nodes (Version: 10.5.1).
I want to upgrade only the IM&P server to the newest version 11.5.1 to use the new Features.
Is it possible to have the CUCM cluster running with the version 10.5.1 and the IM&P cluster running with the version 11.5.1?
Solved! Go to Solution.
08-31-2016 01:52 AM
IM&P is effectively part of the CUCM cluster now, so the major and minor version has to match.
If you want IM&P to be on 11.5.1 CUCM also needs to be upgraded to 11.5.x
Adam
08-31-2016 01:52 AM
Adam
