Compatibility with 12.5SU5
MORNING STAR
Can we go for
1--12.5su5 for CUCM ,CUC, IMP if compatible with be7000h m4 ?
2--12.6 expressway on BE6000M m4
1--12.5su5 for CUCM ,CUC, IMP if compatible with be7000h m4 ? Its compatible.but you need to run supported versions of VMware on Be7K hardware.
2--12.6 expressway on BE6000M m4:-  Its compatible.
You need to refer the below links. and its has all informations regarding compatability What you are looking for.
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/virtualization/cisco-collaboration-virtualization.html
https://www.cisco.com/c/dam/en/us/td/docs/voice_ip_comm/uc_system/unified/communications/system/Compatibility/CSR-Compatibility-Matrix-InteractiveHTML.html
Response Signature
The comp. Version if vm would work be 6.7 update 3 ?
Could you please share ref. Doc for this
I have shared  two links in my initial post. refer the first one and it contains all informations you looking for.
Response Signature
If you took the time to read the provided information by @Nithin Eluvathingal you would see that the answer to your question is given.
Response Signature
