07-01-2016 11:31 AM - edited 03-19-2019 11:19 AM
I have a new implementation with CUCM 11, conductor XC4 and vTS 4.2(4.23). I create a CA to sign the certificates on CUCM and on Conductor and exchanged the certificates. and followed this document for the implementation
The problem is that the media resource group never register on the system and when I try to call a rendezvous room the call fail using any endpoint or Jabber
I got the trace attached from CUCM and from conductor
Can someone help me on it ?
07-01-2016 01:33 PM
You don't need to exchange certificates if you're doing a secure SIP trunk, you just need the root CA in both devices.
Do you see the SIP trunk as in full service?
07-01-2016 01:36 PM
Yes either ad-hoc and rendezvous are in full service
07-02-2016 12:19 PM
Did you look at the traces you posted???
The first lines of the SDL trace show a TLS connection failure in regards to Conductor_SIP_Trunk_Rendezvous
2 | InvalidX509NameInCertificate - Configured X.509 Subject Name doesn't match the name in the certificate from the peer |
I suggest you look into that, if it still fails, review new traces.
Also for rendezvous you don't need the Conductor to register as a CFB, that's for ad-hoc
07-06-2016 04:39 AM
07-06-2016 10:19 AM
Interesting, they updated the bug notes, I knew about that bug since 10.5 but it was supposed to be on its way to be fixed, and now it shows as a Sev6, anyway, glad it's working now for you.
