12-05-2011 06:01 AM - edited 03-19-2019 04:03 AM
We are running Cisco CUCM version 8.5 and have deployed some 6 x Cisco 7942G IP Phones in a Call Centre hunt group setup. We are however getting feedback that these Call Cantre agents cannot conference more than 4 concurrent calls on the confrence facility. Is there any specific setting that we need to look at. Any suggestions are most welcome.
12-05-2011 06:10 AM
This is the default maximum participants available on CUCM systems. It probably affects all your phones...
Go to ccmadmin, System/Service Parameters. Select any server, then the IP Voice Media Streaming Service. You can change the maximum adhoc conference paricipants parameter there.
Aaron
Please rate helpful posts..
12-05-2011 11:03 PM
12-06-2011 12:12 AM
Yes - click 'Advanced'
Aaron
12-06-2011 02:02 AM
12-06-2011 03:08 AM
Apologies - it's actually a parameter of the CallManager service... in the 'Clusterwide Parameters (Feature - Conference)' section.
Aaron
12-06-2011 03:19 AM
Hi Aaron,
Thank you, I found this option and will change and test again.
Pieter
12-07-2011 05:09 AM
This issue has been resolved.
