Conference call limitation on Cisco 7942 IP Phone
serfonpj
We are running Cisco CUCM version 8.5 and have deployed some 6 x Cisco 7942G IP Phones in a Call Centre hunt group setup. We are however getting feedback that these Call Cantre agents cannot conference more than 4 concurrent calls on the confrence facility. Is there any specific setting that we need to look at. Any suggestions are most welcome.
7 Replies 7
Aaron Harrison
This is the default maximum participants available on CUCM systems.  It probably affects all your phones...
Go to ccmadmin, System/Service Parameters. Select any server, then the IP Voice Media Streaming Service. You can change the maximum adhoc conference paricipants parameter there.
Aaron
Please rate helpful posts..
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Good Day Aaron,
Thank you for your advise in the reply, although I do not see this
option under the Service Parameters in order to set. See detail below,
Any other suggestions?
Yes - click 'Advanced'
Aaron
Hi Aaron,
See the detail on the advanced option, no indication of any conference
parameter to set here,
Apologies - it's actually a parameter of the CallManager service... in the 'Clusterwide Parameters (Feature - Conference)' section.
Aaron
Hi Aaron,
Thank you, I found this option and will change and test again.
Pieter
serfonpj
This issue has been resolved.
