Connecting CUCM 8 with CUCME
Jonn cos
Level 4
Level 4
Hi all experts.
I need to connect CUCM v8 with CUCME (2821 running CUCME v7). What protocol shall i use ? MGCP/H323/SIP ?
Kindly guide me
2 Accepted Solutions
Jonathan Schulenberg
My answer is SIP although others may disagree. MGCP is not a peer-to-peer protocol. H.323 would require you to deal with the ECS vs. H.450 issues.
I'd recommend you to read this and then with that info choose the one that you consider is best for your deployment:
Interoperability of Unified CM and Unified CM Express
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/8x/callpros.html#wp1044453
My personal preference is to use H323
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
java
if this helps, please rate
java
java
