CUPC Transfer calls directly to VM
I would like to know if there is a way to transfer an incoming call directly to vm.  I have setup *123 (123 being extension) to go directly to vm on the phycial phone but there does not seem to be a way to complete this same action from the CUPC client.  Is there a way?
5 Replies 5
testeven
There is a button for sending calls to Voicemail. If the option is greyed out, please refer to:
http://www.cisco.com/en/US/docs/voice_ip_comm/cupc/7_0/english/troubleshooting/guide/trouble.html#wp1043853
HTH!
Tere Stevens
Cisco Systems
Unified Communications PDI Team
www.cisco.com/go/pdihelpdesk
Regards, Tere. If you find this post helpful, please rate! :)
Not even a greyed out button, this is CUPC 8.x
Have you configure CUPS > Application > Cisco Unified Personal Communicator > Unity Server and Unity Profile?
Have you assigned the users to profile?
Also the voicemail pilot number needs to be synchronized to CUPS, it should show up in CUPS.
Is this softphone or desktop mode?
Tere.
I don't see anythiing with Unity, but Voicemal Server, Voicemail Profile and Mailstore.  Yes.
Hi Donald,
You would need to configure the following,
In CUPS :
1. Voice mail server and VM profile under CUPS admin - Application - CUPC
2. Associate the VM profile to the user under - CUPS admin - Application - CUPC - user settings
In CUCM,
1. Check the VM profile for the user extension
