03-29-2011 04:38 PM - edited 03-19-2019 02:39 AM
Hi All,
I am just wondering if anyone has been able to get the "Connection Wallet Card Wizard" from the Cisco unity tools depot to work on a 64bit machine.
I have downloaded the Informix drivers from both the unitytools site and from IBM, but I still get the following error when i try and install.
“You must first install the IBM Informix Database drivers. See the download page for this tool for a link to the setup”
The windows installer log shows one message “Error 2732.Directory Manager not initialized”
Any help would be appreciated..
Cheers
Jason
Solved! Go to Solution.
03-29-2011 06:02 PM
Yep. Win7 64bit here also. Same error.
You need the entire client SDK for some reason.
http://www14.software.ibm.com/webapp/download/search.jsp?rs=ifxdl
Free registration required.
03-29-2011 06:02 PM
03-29-2011 07:36 PM
Thanks Anthony,
I had downloaded the SDK but it looks like it didnt install correctly.
Did an uninstall/reinstall and the Card Wizard is now working.
Cheers
Jason
