converting a 4 digit dial plan to 10 digits
DavidPeter
I have been asked to convert a 4 digit dial plan to 10 digits. It was kind of my idea but now I am not sure what the best path would be as I need to do this one site at a time at least to start. I know what to do for the Unity Connections side but on the CUCM side I would like to have them be able to dial the 4 digits without a prepending site code and vice versa dial 10 digits from the other locations without a site code. Is that possible and what would the best means to do this be?
Thanks for any help!
Dave
Jaime Valencia
Configure the translation patterns to do that.
java
if this helps, please rate
Jaime Valencia
java
OK I think I understand. I could have a translation pattern of 85872023XX that is in the partition the 10 digit phones are in and set the CSS for one that has the partition the 4 digit phones are in and set the "calling Party transformation mask" to XXXX to match the 4 digits they are dialing?
I tried and tested what I had below and it worked both directions.  Sometimes just a few words can get you on the right track :) Thank you
