CP-8841 Abbreviated Dialing
daleshew517
Is the Abbreviated Dialing feature available on the CP-8841 telephone?  I added the feature to a softkey template and the speed dial button shows up when I go off hook but my entries don't show up when I press it.  I just get an empty block on the screen.  Call Manager version is 11.5.1.12900-21 and Phone Load is sip88xx.12-7-1-0001-393.
Yes supported.
 https://www.cisco.com/c/en/us/products/collateral/collaboration-endpoints/unified-ip-phone-8800-series/datasheet-c78-731638.html
 Make sure that you done all required  configuration.
  •  Log in Cisco Unified Communications Administration Page
To Display the Phone Configuration window, choose Device > Phone. Enter your search criteria and click Find.
  • Choose the phone/device for which you want to configure speed-dial buttons.
  • From the Phone Configuration window, choose Add/Update Speed Dials from the Related Links drop-down list box at the top of the window and click Go.
The Speed Dial and Abbreviated Dial Configuration window displays for this phone.
  • : Configure the Speed Dial (Abbreviated Dial) numbers and the display label
  •  To apply the changes, click Save.
  •  Reset the phone for the changes to take effect
Response Signature
Yes supported.
Response Signature
