create custom ringer on 7962 model
waldronks
Is there a simple way to create a custom ringer for the 7962 model phone? I am using version 8.0.3 CUCM
Thanks in advance!
--K
Jonathan Schulenberg
Yes using the Phone Designer Widget; however, it has been axed and no longer works starting in CUCM 8.5. Enjoy it while it lasts. Once you upgrade past 8.0 you will have to use the TFTP server RingList method.
5 Replies 5
Thanks! So I downloaded the phone designer and go to open it and receive a pop up "Phone Designer has encountered an issue that requires the application to be closed. If the problem persists please contact your administrator".
Any thoughts on this?
Hi Jonathan
That's interesting - is it the Phone Designer app that is being dropped, or the XML commands that the phones respond to?
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
Not sure but it most certainly doesn't work any more. I had a customer that upgraded to 8.5 - having forgotten all about giving a few departments Phone Designer - and wow did I.T. hear about it after the upgrade. It got escalated to the account team but there is no planned replacement for it apparently.
Hmm.. must fire up the lab then tomorrow - I've written a similar tool for use by admins/engineers for bulk deployment. I'll be disappointed if it stops working :-)
