ā12-23-2010 07:56 AM - edited ā03-19-2019 02:07 AM
Good evening, Gents!
I've got 2 CRS (Customer Responce Solution) servers, on in the main office (CRS1) and one in remote location (CRS2)
I also have 2 CUCM servers in cluster, one in the main office (CCM1) and one in remote office (CCM2).
Now the problem is that CTI Route Points from CRS2 register with CCM1 and one CTI Route Point from CRS1 registers with CCM2 thus when VPN goes down CRS2 doesnt work and responce.
I have checked Unified CM Configuration page on CRS 2, everything seems to be ok, CCM2 is listed the first node. But CRS2 keeps registering with CCM1
Dont know where to look for solution!
Thank you in advance!
Solved! Go to Solution.
ā12-24-2010 12:09 AM
And you have the CTI Route point, and CTI ports in your call control group assigned to a Device Pool that has CCM2 as primary? I was thinking you said you did in your initial post, but when I re read it, I'm not clear on that. That is going to control where those ports register.
Cliff
ā12-23-2010 08:09 AM
What version are you running of CCX and UCM?
ā12-23-2010 09:49 AM
Sorry, forgot to mention. CUCM 6 and CCX 5.0
ā12-23-2010 12:15 PM
Open the appadmin interface, and take a look at the telephony subsystem setup and the RMCM setup.
Within each, you have an ordered list of providers. It will use the one at the top of the list first. My bet is that you have them backwards from what you're wanting.
Cliff
(please rate helpful posts. Also, please mark response that provide you with an answer as a solution so that others can find answers more easily)
ā12-23-2010 09:52 PM
Clifford,
I have checked it already, they are listed in correct order, on CRS2 CCM2 is listed the first, but still, it keep registering with CCM1
Cliff
ā12-24-2010 12:30 AM
ā12-24-2010 12:33 AM
I changed device pool under trigger configuration, now it registers correctly! Thank you very much!
