06-21-2018 02:08 PM - edited 03-19-2019 01:25 PM
Upgrading from CUAC 10.5 to 12. I built a new server, and migrated the database. I am not able to login to the application administrator. The password that works on the original production box does not work on the migrated, neither does cisco or CISCO. I found an article for changing the password on v8 with a SQL query, but when I run the query I get an error.
UPDATE [ATTCFG].[dbo].[Agent_Details]
SET Password = NULL
WHERE Login_Type = 'SUP' AND Login_Name = 'ADMIN'
Invalid column name 'Password'.
Is there a password recovery procedure for modern versions of CUAC?
03-12-2019 01:39 PM
Did you ever get this resolved? There is no documentation available in admin guide as well.
Sami
03-27-2019 05:56 AM
Hello everyone,
When you do upgrade to 12.x all passwords got capitalized by default.
Let say you had following password on 11 version - PaSSword
When upgraded to 12.x password will be as follows - PASSWORD
Also procedure for password reset which is mentioned by topic-starter in not applicable in CUAC 12.x. Please reach out to Cisco TAC for password reset operations.
