CUAC Advanced 11 Password Recovery
Ahochau
Upgrading from CUAC 10.5 to 12.  I built a new server, and migrated the database.  I am not able to login to the application administrator.  The password that works on the original production box does not work on the migrated, neither does cisco or CISCO.  I found an article for changing the password on v8 with a SQL query, but when I run the query I get an error.
UPDATE [ATTCFG].[dbo].[Agent_Details]
SET Password = NULL
WHERE Login_Type = 'SUP' AND Login_Name = 'ADMIN'
Invalid column name 'Password'.
Is there a password recovery procedure for modern versions of CUAC?
Sami Ahmad
Did you ever get this resolved? There is no documentation available in admin guide as well.
Sami
Hello everyone,
When you do upgrade to 12.x all passwords got capitalized by default.
Let say you had following password on 11 version - PaSSword
When upgraded to 12.x password will be as follows - PASSWORD
Also procedure for password reset which is mentioned by topic-starter in not applicable in CUAC 12.x. Please reach out to Cisco TAC for password reset operations.
