CUBAC - Release of a transferred call from ATC
bcorbet2004
Does anyone know if there is a why to have CUBAC release a transferred call to the destination?  I have set the Transfer Recall to '0' in order to disable it, but when the call is blind transferred the callerID still shows one of the CUBAC CTI ports instead of the original calling party information.
Brian C.
Rob Huffman
Hi Brian,
Here's one excellent related thread
https://supportforums.cisco.com/thread/2105407
Cheers!
Rob
When looking that the registry location referenced in the other thread it does not appear to be available in CUBAC.  Is this only a CUEAC?  Or is it version specific thing?  We are running 8.6.2.11.
When we tried to add the value it did not take affect.  Does it require a reset of services to enable it?
Brian Corbet
This is available in all editions.
Make sure you log out of the console and close it before trying to make the change
