02-08-2021 05:39 AM
I have a CUBE between ITSP and CUCM. I would like to modify the From header received in the incoming INVITE and use it in the outgoing INVITE
Received:
INVITE sip:+496xxxxxxxx46@192.168.1.10;user=phone SIP/2.0
Max-Forwards: 68
Session-Expires: 3600;refresher=uac
Min-SE: 600
Supported: timer, 100rel
To: "+496xxxxxxxx46" <sip:+496xxxxxxxx46@192.168.1.10;user=phone>
From: "+316xxxxxxx7" <sip:+316xxxxxxx7@212.10.1.34>;tag=3821351883-1068052432
P-Asserted-Identity: "+4930xxxxxxx10" <sip:+4930xxxxxxx10@212.10.1.34;user=phone>
Call-ID: 264551051-3821351883-200638263@SBC1-ABC-EU.exemple.com
CSeq: 1 INVITE
Allow: MESSAGE,PRACK,INFO,OPTIONS,BYE,INVITE,ACK,CANCEL
Via: SIP/2.0/UDP 212.10.1.34:5060;branch=z9hG4bKb005fb6fc6c3f229959ef2d648333f2c
Contact: <sip:+316xxxxxxx7@212.10.1.34:5060>
Content-Type: application/sdp
Accept: application/sdp
Content-Length: 347
v=0
o=SBC2-ABC-EU 2496788555450729 1 IN IP4 212.10.1.34
s=sip call
c=IN IP4 212.10.1.35
t=0 0
m=audio 65102 RTP/AVP 8 0 18 96 13 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no
a=rtpmap:96 G726-32/8000
a=rtpmap:13 CN/8000
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-15
a=sendrecv
Sent:
INVITE sip:+496xxxxxxxx46@10.218.11.13 SIP/2.0
Via: SIP/2.0/TCP 10.10.128.66:5060;branch=z9hG4bK1A325E32C
From: "+4930xxxxxxx10" <sip:+4930xxxxxxx10@10.10.128.66>;tag=96988838-F0A
To: <sip:+496xxxxxxxx46@10.218.11.13>
Date: Wed, 03 Feb 2021 13:41:57 GMT
Call-ID: 6B783808-655C11EB-9F6CFE9F-76F149F1@10.10.128.66
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE: 600
Cisco-Guid: 1803010717-1700532715-2674327199-1995524593
User-Agent: Cisco-SIPGateway/IOS-16.6.4
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Timestamp: 1612359717
Contact: <sip:+4930xxxxxxx10@10.10.128.66:5060;transport=tcp>
Call-Info: <sip:10.10.128.66:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: telephone-event
Max-Forwards: 67
P-Asserted-Identity: "+4930xxxxxxx10" <sip:+4930xxxxxxx10@10.10.128.66>
Session-ID: d6e6a4ea31b55239a00a08ee52f06598;remote=00000000000000000000000000000000
Content-Disposition: session;handling=required
Content-Length: 298
v=0
o=CiscoSystemsSIP-GW-UserAgent 7598 4889 IN IP4 10.10.128.66
s=SIP Call
c=IN IP4 10.10.128.66
t=0 0
m=audio 45722 RTP/AVP 8 0 101 19
a=fmtp:101 0-15
a=rtpmap:19 CN/8000
a=ptime:20
I tried following but it failed
voice class sip-copylist 50
sip-header FROM
dialpeer voice 100 voip
voice class sip-profiles 50
request INVITE peer-header sip From copy "sip:(.*)@" u01
request INVITE sip-header From modify ".*@(.*)" "INVITE sip:\u01@\1"
dial-peer voice 100 voip <<<<<< FROM ITSP
dial-peer voice 400 voip <<<<<<< To CUCM
voice-class sip profiles 50
Can someone review the above and advise what went wrong and if I missed something?
Thanks in advance
Solved! Go to Solution.
02-08-2021 10:07 AM
Have a look at this post, it sounds like it should be similar to what you ask.
02-12-2021 06:21 AM - edited 02-12-2021 06:22 AM
Hi Roger,
Finally I got it working. Thanks for your help.
It was not an easy one as the SIP Profiles Test Tool may show you as working while you still have an extra \ at the end of the number. So on cube this will of course not work.
Here is the working config, it may help and save some time for others:
voice class sip-profiles 10
request INVITE peer-header sip From copy "<sip:(.*)@" u01
request INVITE sip-header From modify ".*@(.*)" "From: \"\u01\" <sip:\u01@\1"
request INVITE sip-header P-Asserted-Identity modify ".*@(.*)" "P-Asserted-Identity: \"\u01\" <sip:\u01@\1"
voice class sip-copylist 10
sip-header From
dial-peer voice 50 voip <<<<<<<<<<<<<< From ITSP
voice-class sip copy-list 10
dial-peer voice 100 voip <<<<<<<<<<<<<< To CUCM
voice-class sip profiles 10
02-08-2021 10:07 AM
02-08-2021 01:28 PM
Thanks Roger,
I prepared the config I think correct now. I will apply it tomorrow to the CUBE and test. Will let you know.
02-08-2021 10:02 PM
If you want to pre test the SIP profile I recommend you to look through this document about the test tool for SIP profiles that Cisco have provided for us. https://community.cisco.com/t5/collaboration-voice-and-video/sip-profile-test-tool/ta-p/3162632
Hi Roger,
sip-header From
02-12-2021 06:26 AM
Glad you managed to get it work. One question, was it intentional that you marked your own reply as the answer to your post?
02-12-2021 06:54 AM
No, that was not intentional. your first reply did put me really in the right direction.
