CUBE not showing active calls but only if on Hold
danntel01
Hi Community,
I'm having this weird behavior with my CUBE (csr100v)
For an active call, when searching with the following command, i get nothing as the output, as you can see here:
hq-vcube1#show call active voice brief | i pid
<ID>: <CallID> <start>ms.<index> (<start>) +<connect> pid:<peer_id> <dir> <addr> <state>
But, if i Hold the call from one of the endpoints, then yes, i do get the following output:
0 : 5168 84976050ms.1 (21:19:11.700 PST Mon Jan 28 2019) +5810 pid:10 Answer +14085151111 connected
0 : 5169 84976060ms.1 (21:19:11.710 PST Mon Jan 28 2019) +5790 pid:20 Originate +14082022001 connected
hq-vcube1#
The same behavior applies for command "sh call active voice comp", when i'm on an active call, i get nothing:
hq-vcube1#show call active voice compact
hq-vcube1#
When on Hold:
<callID> A/O FAX T<sec> Codec type Peer Address IP R<ip>:<udp> VRF
Total call-legs: 2
5168 ANS T342 g711ulaw VOIP P+14085151111 10.201.238.131:4000 NA
5169 ORG T342 g711ulaw VOIP P+14082022001 10.201.238.122:25332 NA
Any ideas on why this could be happening?
Thanks!
6 Replies 6
Ratheesh Kumar
Hi there
Can you find active calls using these commands
show call active voice brief | incl call-legs
sh sip-ua call su
Show voip rtp connections
sh call active voice summary
sh sip-ua calls summary
Also try RTMT >> "Trunk Activity" under Voice/Video section
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
This is what i get for those commands:
hq-vcube1#show call active voice brief | incl call-legs
Telephony call-legs: 0
SIP call-legs: 0
H323 call-legs: 0
Call agent controlled call-legs: 0
SCCP call-legs: 0
Multicast call-legs: 0
Total call-legs: 0
hq-vcube1#
hq-vcube1#
hq-vcube1#sh sip-ua call su
Total SIP call legs:2, User Agent Client:1, User Agent Server:1
hq-vcube1#
hq-vcube1#
hq-vcube1#show voip rtp connections
VoIP RTP Port Usage Information:
Max Ports Available: 19999, Ports Reserved: 101, Ports in Use: 4
Port range not configured
                                        Min   Max   Ports     Ports     Ports
Media-Address Range                     Port  Port  Available Reserved  In-use
Global Media Pool                       8000  48198 19999     101       4
VoIP RTP active connections :
No. CallId     dstCallId  LocalRTP RmtRTP   LocalIP                                     RemoteIP                                  MPSS  VRF
1     5176       5177       8198     19874    10.201.238.149                            10.201.238.135                            NO    NA
2     5177       5176       8200     17730    10.201.238.104                            10.201.238.122                            NO    NA
3     5178       5179       8202     19784    10.201.238.104                            10.201.238.122                            NO    NA
4     5179       5178       8204     30486    10.201.238.149                            10.201.238.135                            NO    NA
Found 4 active RTP connections
hq-vcube1#sh call active voice summary
SIP call-legs: 0
H323 call-legs: 0
SCCP call-legs: 0
Total call-legs: 0
hq-vcube1#sh sip-ua calls summary
hq-vcube1#
Any ideas please?
Hi there
I am curious to know whether its a cosmetic bug hitting the IOS. Have you tried an IOS upgrade followed by a reload of router. Its worth trying that.
Hope this Helps
Cheers
Rath!
Upgrade won't help that much.
Doing some research, I noticed that if i run the same command while in ringing state, then i get output:
generic_show_call_active_func: Message GET_VOICE_TXRX send failed!0 : 7254 187958010ms.1 (14:22:57.814 PST Fri Feb 1 2019) +-1 pid:14 Answer +14082022001 connecting
0 : 7255 187958020ms.1 (14:22:57.824 PST Fri Feb 1 2019) +-1 pid:2 Originate 19725252222 connecting
vcube1#
But once i accept the call:
vcube1#
Running the following command (again, the call is active right now), it works:
vcube1#show call active video brief | i pid
generic_show_call_active_func: Message GET_VOICE_TXRX send failed!0 : 7254 187958010ms.1 (14:22:57.813 PST Fri Feb 1 2019) +15960 pid:14 Answer +14082022001 active
0 : 7255 187958020ms.1 (14:22:57.823 PST Fri Feb 1 2019) +15930 pid:2 Originate 19725252222 active
vcube1#
Notice i had to use video and not voice in the command.
This seems to be working by design.
IvoZZ
