Bookmark
Subscribe
752
CUCM 11.5 Disaster Recovery and PLM backup option when using separate PLM server
We have a CUCM 11.5 cluster and a separate PLM server that manages licensing for CUCM CUC CER. My question is should I include the (Select the check box) for the PLM when setting the automated backup schedule for CUCM, and CUC?
Jaime Valencia
There's no PLM data if you're not using it.
java
if this helps, please rate
As you use a separate server for PLM there is no need to select these on the individual systems.
Response Signature
