CUBE Source Port
Flo.Matalis
b.winter
When you use SIP over UDP, then you can use the command "connection-reuse via-port".
For TCP, I haven't seen such command yet.
But does the provider want, the all SIP messages come from source port 5060?
Or that the INVITE's come from the same source port, that was originally used in the REGISTER message?
Because those are 2 different requirements.
Maybe you could spare a few more letters on your post to make the wanted outcome somewhat clearer? For example, but not limited to, start by mentioning the platform that your question applies to?
Response Signature
