CUCILync Problems
James Hawkins
Level 8
Level 8
I am trying to install CUCILync using the Cisco documentation and am not having much luck.
I have configured the client to use EDI and have entered the registry values manually.
When I run Lync the CUCI part is shown and populated with the correct user name but when I enter the password and click "Sign In" I get a message "Cannot connect to server. Please contact your system administrator"
Can anyone tell me which server CUCILYNC is trying to connect to? - is it an LDAP server, CUCM server???
For some reason the software does not seem to be creating any log files.
James Hawkins
Level 8
Level 8
Have taken an Ethereal trace and it is trying to contact one of the CUCM subscribers using TCP port 8443.
I can login to ccmuser on this server from the PC running CUCILync - any ideas?
Can you post your registry config?
Have you looked at the logs, the core log is pretty helpful.
Chris
