Unity & Call Forwarding
stlieser
I'm using UCM & Unity Connection 8.6 and have the following problem:
Calls to the attendant user (ext 100) are forwarded to voice mail.
Another "normal" user (ext 200) has forwarded all calls to his phone to the attendant extension 100.
When you call user (200) you can here his personal message and NOT the message of the attendant.
Why the message of the attendant isn't played?
Thanks for any suggestions
Marcus
Rob Huffman
Hi Marcus,
This is actually working as designed
Unity Connection (by default) uses the Originally Dialed Number
when routing calls to the applicable voicemail box.
You can have a look into this System Wide setting which is available in Unity Connection;
Via
Cisco Unity Connection Administration
Advanced (towards the bottom of the page)
Conversation Configuration
**Use Last (Rather than First) Redirecting Number for Routing Incoming Call**
You would need to think about what impact this might have on your setup.
Cheers!
Rob
"May your heart always be joyful
May your song always be sung" - Bob Dylan
Rob Huffman
Hi Marcus,
Via
Cheers!
Rob
Hi Rob,
thank you very much for the quick and useful clarification!
Marcus
