CUCIMOC installation - Client Services Framework Device
andyhibbert
I'm looking at installing CUCIMOC with a UCM 6.1.3.3190. Reference is made in the release notes to having the Client Services Framework device installed on the UCM. How can I tell if this has already been installed ? What am I looking for on the UCM. ? I don't see anything listed under the Device tab on the UCM admin page.
If you're not seeing "Cisco Unified Client Service Framework" in the device list, it's not installed.
Michael
7 Replies 7
htluo
Level 9
Level 9
For 6.1.3, you need to install a COP file, so the CSF would show up in the device list.
Michael
http://htluo.blogspot.com
It's possible that the COP file has already been installed. I can't get hold of the person who did the installation to ask. So I was wondering if there was a way of checking?
Michael
Guys where i can get the cop file , isearched for it in downloads section for version CUCM 6.1.3 and nothing appeared in device packages as COP file .
I still cant find the framework file. Anyone locate it? Or is it in the device pack?
ok, I found it. Its actually in the zipped file you download from the CCO unified communications client then Cisco UC Integration(TM) for Microsoft Office Communicator link.
If you unzip the file, its all in there. (dial COP, etc)
