05-01-2019 06:03 AM
Last time I configured IPhones in CUCM with IPs addresses provided by the router but unfortunately because of same failure we setup the router again and now the Phones got others IPs different with I've registered before in CUCM. Resuming How can I update CiscoPhoneIP addresses in CUCM without delete. Thanks in advance.
Solved! Go to Solution.
05-02-2019 01:20 AM
As long as there's IP reachability between the phones and cucm, there's nothing else you need to do. CUCM doesn't care about which DHCP address is assigned to which phone.
05-02-2019 11:18 AM
Thanks. Problem solved, the Ipphone reached the IP from the router and the CUCM automatically updated the IPs and registered with the new phone's ip.
05-02-2019 01:20 AM
05-02-2019 11:18 AM
