10-09-2013 11:39 AM - edited 03-19-2019 07:22 AM
Question. we are Running the CUCMBE 8.6 and the original setup from a vendor they put the starting directory number at 1000 and ending directory number at 1200. These would auto-register as a phone was plugged in. Below is from the 'Cisco Unified CM Configuration' screen
My problem is if I change the 1200 to say 1300 and hit save, nothing happens. I plug in new phones it appears to get an ip address but it just keeps spinning and nothing happens. So It appears it still will not auto-register anymore phones. We have the licenses so I am wondering what the issue is. Do i need to stop and restart a service?
Also On that page I have the option for apply config. I hit just save which I assume does the same thing. Do I need to hit apply config instead? This is a live system so obviously I want to read lightly and not take it down.
10-10-2013 11:55 AM
That won't work, autoregistration is not dynamic, it won't go back and check whether DNs have been deleted and are available or not.
There are only 3 fields that matter for autoreg in the DB, lower limits, upper limit, and a field which is nextDN to assign, and it will keep going up until that field is equal to the DN upper range limit.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-10-2013 12:38 PM
So what do you recommend as a next step? We have about 20 new phones.
10-10-2013 10:56 PM
Hi Todd,
As asked earlier, can you please check and share us the status from the new phone settings? (if possible then share that snapshot)
And as suggested by rob & Jamie, you can try that by setting the lower and upper limit range from one of the registered DN.
For ex:- If 1150 & 1151 DN is assigned, then without deleting that existing DN set auto-range from 1150 to 1151 and see if phone dislplays some "Registration Rejected" or " Security Error" or any other message.
After that you can try deleting that DN and again check for the message you get in phone display.
Nishant Savalia
