08-25-2012 05:42 AM - edited 03-19-2019 05:26 AM
I have MCS-7835 with windows operating system and there is also CUCM 8.0 installed. the question is how i can delete 8.0 and installed 8.6. Is there any document??
Any help will be highly appreciated.
08-25-2012 06:13 AM
HI Shaikh,
Please refer the below link for CUCM 8.6 install,
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/cucm/install/8_6_1/install/cmins861.html
Also please ensure that the existing harware is supported from the below link,
Hope it helps.
Anand
Please rate helpful posts by clicking on the stars below the right answers !!
08-25-2012 06:25 AM
Thanks .. but there is confusion shall we use windows OS for this installation ?? i mean it can be done??
08-25-2012 06:29 AM
Hi Shaikh,
CUCM 8.6 works on Linux not on windows. You just need the CUCM installer (DVD), if you are planning to install it fresh just insert it and use the install guide to for step by step instructions.
Hope it helps.
Anand
Please rate all helpful posts !!
08-25-2012 06:30 AM
How it can be to use cucm 8.x version with OS windows??
When you insert a disk for a new installation from version 5.x and later if i am correct the cd built a linux OS and also built the cucm application
chrysostomos
08-25-2012 08:00 AM
There is no Windows version CUCM, the last Windows version was 4.3 which is quite old, anything starting with version 5 has been Linux appliance, which means you do not install OS as it is embaded within the Cisco CUCM installer.
HTH, please rate all useful posts!
Chris
08-25-2012 03:48 PM
In this case , there was an issue with MCS server and IBM enigneer upgarded the BIOS of server and he installed Windows OS
to do the upgrade.
