01-12-2024 10:12 PM
We are upgrading our core switches. During this process, the CUCM publisher and subscriber will be temporarily disconnected from the LAN network. Will this affect the CUCM cluster? Do we need to shut down the CUCM cluster servers during this time?
Solved! Go to Solution.
01-13-2024 12:00 AM
Assuming that your CM publisher and subscriber is in the same IP network it won’t even be noticed by the cluster nodes. That said, you should not need to do anything when changing out your core switches, even if the cluster nodes were in different IP networks. They will reconnect with each other once the network is operational again.
01-13-2024 12:00 AM
01-14-2024 02:11 AM
thank you. we didnt shutdown the servers. it worked properly without any issue.
