CUCME Voice hunt-group issue when transfer to external number
I have a CUCME 7.X.
I configured a voice hunt-group and list number with external numbers. When I call to the pilot using a internal phone it works! But if this hunt received a external call, it didn´t works. The call stay in silent and then get a busy tone. Please, can anyone help me?
The configuration:
voice hunt-group 100 parallel
pilot 2929
list 0XXXXXXXX, 0XXXXXXX
Thanks!!
Jorge Armijo
Level 4
Level 4
Please provide:
-Complete call flow
-Full CME configuration
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
The call flow:
PSTN --> 2929 (PILOT NUMBER) --> 0XXXXXXXX,0XXXXXXXX (LIST OF THE HUNT, EXTERNAL MOBILE PHONE) --> PSTN (INTERFACE E1) --> AFTER A TIME, GET A BUSY TONE!!
SCCP PHONE --> 2929 (PILOT NUMBER) --> 0XXXXXXXX,0XXXXXXXX (LIST OF THE HUNT, EXTERNAL MOBILE PHONE) --> PSTN (INTERFACE E1) --> WORKS PERFECT!!
The CME configuration:
boot-start-marker
boot-end-marker
card type e1 0 1
card type e1 0 2
logging message-counter syslog
logging buffered 5000
no logging console
enable secret 5 $1$37RW$TV6Lud8fM5g6ikUr3XAL31
aaa new-model
aaa session-id common
clock timezone PCTime -3
network-clock-participate wic 1
network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.55.32.1 10.55.32.20
ip dhcp pool voz
   network 10.55.32.0 255.255.255.0
   option 150 ip 10.55.32.1
   dns-server 10.55.13.24 10.1.14.206
   domain-name crb.apmoller.net
   default-router 10.55.32.2
   lease infinite
no ip domain lookup
ip domain name maerskvoip
frame-relay switching
trunk group  ATT
carrier-id VOIP_ATT
hunt-scheme random
voice-card 0
no dspfarm
dsp services dspfarm
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
sip
  registrar server expires max 1200 min 300
voice class codec 1
codec preference 1 g729r8
codec preference 2 g729br8
codec preference 3 g711ulaw
codec preference 4 g711alaw
voice class h323 1
h225 timeout tcp establish 5
voice translation-rule 10
rule 1 /^00800/ /00800/
rule 3 /^00500/ /00300/
rule 4 /^000/ /00031/
rule 5 /^00/ /0031/
voice translation-rule 20
rule 1 /^5$/ /#/
voice translation-profile ATT
translate called 20
voice translation-profile insere_operadora_LD
translate called 10
pilot 2929
list 0XXXXXXXX, 0XXXXXXXX
controller E1 0/1/0
framing NO-CRC4
ds0-group 0 timeslots 1-15,17-31 type r2-digital r2-compelled ani
cas-custom 0
  country brazil
  metering
  debounce-time 10
  answer-signal group-b 1
  dnis-digits min 1 max 4
  description ** Conexao com PSTN **
interface Loopback1
description INTERFACE PARA MOH PSTN
ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet0/0
description $ES_LAN$
ip address 10.55.32.1 255.255.255.0
duplex auto
speed auto
media-type rj45
no snmp trap link-status
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.55.32.1
service-policy input MARCACAO
interface GigabitEthernet0/1
no ip address
shutdown
duplex full
speed 100
media-type rj45
interface Serial0/0/0
description MPLS TELEFONICA - 1024KBPS
no ip address
encapsulation frame-relay IETF
load-interval 30
no fair-queue
frame-relay traffic-shaping
frame-relay lmi-type q933a
interface Integrated-Service-Engine4/0
ip unnumbered GigabitEthernet0/0
service-module ip address 10.55.32.10 255.255.255.0
service-module ip default-gateway 10.55.32.1
no keepalive
dial-peer voice 1 pots
tone ringback alert-no-PI
description ROTA PARA PSTN
translation-profile outgoing insere_operadora_LD
  paramspace callsetup after-hours-exempt FALSE
destination-pattern 9T
fax rate disable
no digit-strip
no register e164
preemption level flash-override
dial-peer voice 2 voip
description ROTA PARA CCM PUBLISHER
destination-pattern 2...
voice-class codec 1
voice-class h323 1
session target ipv4:10.55.14.1
dial-peer voice 3 voip
preference 1
destination-pattern 7...
voice-class codec 1
voice-class h323 1
dial-peer voice 21 pots
trunkgroup ATT
description ROTA VOIP AT&T
destination-pattern #
dial-peer voice 4 voip
preference 2
destination-pattern 38..
voice-class codec 1
voice-class h323 1
session target ipv4:10.55.5.20
dial-peer voice 100 voip
description *** Dial-peer Unity ***
destination-pattern 1...
session protocol sipv2
session target ipv4:10.55.32.10
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 10 pots
preference 1
destination-pattern 0T
direct-inward-dial
port 0/1/1:0
dial-peer voice 11 pots
  preference 2
direct-inward-dial
port 0/2/0:0
dial-peer voice 31 pots
trunkgroup ATT
destination-pattern 99
dial-peer voice 32 pots
trunkgroup ATT
destination-pattern 98
prefix 2001,80,3363
telephony-service
sdspfarm transcode sessions 10
no auto-reg-ephone
authentication credential
load 7911 SCCP11.8-3-3S
load 7912 CP7912080003SCCP070409A
load 7960-7940 P00308000500
max-ephones 262
max-dn 300
ip source-address 10.55.32.1 port 2000
service phone videoCapability 1
timeouts interdigit 3
system message Maersk Supply Service
url services http://10.55.32.10/voiceview/common/login.do
url authentication http://10.55.32.1/CCMCIP/authenticate.asp
cnf-file location flash:
cnf-file perphone
date-format dd-mm-yy
keepalive 60 auxiliary 60
voicemail 1010
max-conferences 8 gain -6
call-forward pattern .T
moh music-on-hold.au
web admin system name  password
dn-webedit
time-webedit
transfer-system full-consult
transfer-pattern .T
transfer-pattern #T
secondary-dialtone 0
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn  1  dual-line
number 2803
label Urca Meeting Room
name Urca Meeting Room
translation-profile incoming ATT
ephone-dn  2  dual-line
number 2801
label Catete Meeting Room
name Catete Meeting Room
ephone  1
no multicast-moh
mac-address 0016.4705.10C3
type 7940
button  1:1
ephone  2
no multicast-moh
video
mac-address 0018.180E.410D
type 7940
button  1:2
line con 0
line aux 0
line 258
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
transport input telnet ssh
line vty 5 15
transport input ssh
scheduler allocate 20000 1000
end
YouR topology/callflow aren´t clear...
You can post debug voice ccapi inout or debug isdn q931 with work and not work flow?
Please give us the Called and calling number
Cheers
Bruno Rangel
"Se você quiser alguém em quem confiar, confie em si mesmo. Quem acredita sempre alcança"
Renato Russo
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
I´m trying to explain again:
I created a voice hunt-group where the members of this hunt are external numbers. When I call to the pilot (2929) using a SCCP Phone, works perfectly. But when I am out of the ofice and call to the pilot 3202-2929) using the PSTN don´t work.
Regards!
