CUE / CCM Integration
canowlin
Can you tell accomplish the task below?
I'm getting JTAPI Loging Failed Error while determining CCM version -1
CUCM is 4.2(3)
CUE is 2.3(2)
Another forum user explained this would solve my issue?
http://<callmanager>/CCMPluginsServer/CiscoJTAPIClient.exe on port 80. IIS in the CallManager is configured to "require SSL" in the CCMPluginsServer directory. After disabling that requirement in IIS, the CUE setup was able to continue.
5 Replies 5
aghaznavi
Level 5
Level 5
This implies that we probably have a license file for CallManager Express, rather than CallManger.Refer URL
http://www.cisco.com/univercd/cc/td/doc/product/voice/unityexp//rel2_1/cmecligd/ch2a_upg.htm#wp1122572 for more information.
Actually, if you have the wrong license, it won't even ask you for the JTAPI/CallManager integration stuff. I'm not sure about the original question. You do have to disable SSL for that directory for it to work properly.
I had a problem with UnityExpress accessing jtapi.jar. I changed the Anonymous user for the default web site to CCMUser and everything works fine. There is a bug that say's to turn off SSL in the web site directories but that didn't work. Everything is working great now.
Calude,
Have you expereince a problem were IP communicator is not able to stay connected to CUE or messages saved to CUE are never recorded completely?
Just started using this, I'm a Unity person myself. The original issue Cisco has opened a Bug on with a service release for fix. I am having MWI issues with Communicator right now, but that is across VPN (IPSEC) tunnel.
