CUE Licensing Issue
andyvassar
I have a SM-SRE-710-K9 module running CUE software version 8.6.7 installed in a Cisco 2911 running 15.2(4)M4 and can not get the licenses to work to save my life.  This licensing system is confusing and even after reading this forum for quite some time, I was not able to come up with an answer.
When I configure the CUE module through the web under Voice Mail --> Call Handling, I type the pilot number and use a value of "10" for maximum sessions.  I then get the message "Warning:  Number of sessions exceeds license limit.  Do you want to continue?"  Then, when I try to dial the pilot number for CUE, I get a "SIP/2.0 486 Busy Here" message and hear a busy tone on the phone.
After reading through these forums, I ran the command, "show license all" and got the following output:
CUE# sh license all
License Store: Evaluation License Storage
StoreIndex:  0  Feature: VMIVR-VM-MBX                      Version: 1.0
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
            Evaluation total period:  8 weeks  4 days
            Evaluation period left:  8 weeks  4 days
        License Count: 600 / 0
        License Priority: None
StoreIndex:  1  Feature: VMIVR-PORT                        Version: 1.0
        License Count: 60 / 0
StoreIndex:  2  Feature: VMIVR-IVR-SESS                    Version: 1.0
I saw that the license was "Active, Not in use", so logically speaking all I have to do is put it to use, right?  So I entered the command "license activate voicemail mailboxes 10" and accepted the EULA by typing "y".  I then typed "license activate ports 10" and accepted the EULA by typing "y".  I then typed "license activate ivr sessions 10" and accepted the EULA by typing "y".  I then reloaded the router.  Now when I run the command “show license all”, I get the following output:
CUE# sh license all
        License State: Active, In Use
            Evaluation period left:  8 weeks  3 days
            Expiry date: Tue Aug  5 04:47:44 2014
        License Count: 600 /10
        License Priority: Low
        License Count: 60 /10
This output seemed encouraging.  However, when I type the command “show license status application”, I get the following output:
CUE# show license status application
voicemail disabled, ivr session quantity (10) is equal to or exceeds available ports (10)
ivr enabled: 10 sessions
It looks like the ports and IVR features are active, but for some reason, voicemail is disabled.  What am I missing here?
Rob Huffman
Hi Andy,
The problem here, I believe, is that the IVR sessions = 10 is chewing up all the available Ports (= 10)
Here's an excerpt from an excellent doc;
Common error message:
CUE8-0-1# show license status application
voicemail disabled, ivr session quantity (8) is equal to or exceeds
available ports (8)
ivr enabled: 8 sessions
IVR sessions reduce the number of sessions available for VM.
VM Sessions = Ports minus IVR Sessions.
If Ports = 8 and IVR Sessions = 8 then VM Sessions = 0
Majority of the users do not use IVR features so you may not install and/or activate an IVR license.
CUE# license activate ?
  ivr               Activate IVR feature license
  ports             Activate CUE/IVR ports license
  voicemail         Activate CUE voicemail feature license
Please issue 'license activate ivr sessions N' where N should be 0, 2,
or 4 or 6 so that voicemail will get 8-N sessions, then issue 'reload'.
From;
https://communities.cisco.com/docs/DOC-17720
Cheers!
Rob
Rob Huffman
Hi Andy,
available ports (8)
From;
Cheers!
Rob
That worked!  So if I understand this correctly, you need a port license in addition to a mailbox license, which sets the amount of mailboxes or IVR sessions you can have.
For example, if you have 10 port licenses, you can have any combination of mailboxes and IVR sessions that add up to 10.  Well, in this case it’s only two combinations since the mailboxes have to be in increments of 5:
10 Port Licenses
5 Mailbox Licenses
5 IVR Licenses
10 Port Licenses
10 Mailbox Licenses
0 IVR Licenses
If my logic is correct, the following makes sense for a permanent license, correct?  We only have a need for 5 mailboxes and 3 IVR sessions.
8 Port Licenses
5 Mailbox Licenses
3 IVR Licenses
Hi Andy,
You are on the right track here but with one small correction smiley
Only the IVR sessions need to be less than the total number of ports. You could probably run 60 mailboxes (or more) with 10 ports as they are not based on a one to one relationship just the number or simultaneous mailbox connections to CUE. But each IVR session does reserve one of the ports so it can't be used for mailbox access (make sense??) thus the total IVR sessions must be less than the available ports as we noted in the first part of this thread.
Cheers!
Rob
Thank you Rob!  I appreciate the help.
