CUPC- Reset defaults
Michael Osland
Is there a way to reset the cupc back to defaults.  We have a user that has some how managed to maximize the client, but the buttons to close or minimized the client are out of view.  We have tried moving the window but it won't let us.   We have tried to uninstall and reinstall, but it is remembering the last window size that was used.
ronpatel
Level 8
Level 8
Are you using some kind of extended monitor. May be you are been hit by folllowing bug.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCtl97134
Ronak Patel
Please rate helpful posts.
Regards Ronak Patel Rate all helpful post by clicking stars below the answer.
Gajanan Pande
Mike,
Just reinstall perhaps would not help. Did you clear the registry entries & try installing it again ?
GP.
Pls rate helpful posts !!
ronpatel
Level 8
Level 8
Ronak Patel
