10-17-2011 02:45 AM - edited 03-19-2019 03:47 AM
I am trying to integrate CUPS 8.5 with Exchange 2010 to share calendar information. This requires SSL.
The VeriSign certificate that my customer has provided uses Subject Alternative Names - see link below:
http://www.verisign.com/ssl/buy-ssl-certificates/subject-alternative-name-certificates/
The main certificate name is www.company.co.uk. It contains the following as Subject Alternative Names:
portal.company.co.uk
remote.company.co.uk
mail.company.co.uk
imap.company.co.uk
pop.company.co.uk
CUPS needs to use the mail.company.co.uk name.
I have two questions.
1. Should CUPS work with this type of certificate or will it need one with mail.company.co.uk as the main name?
2. Where can I find logs for troubleshooting CUPS connections?
Solved! Go to Solution.
10-27-2011 09:02 AM
No... he said that he did not know (or wasn't allowed to say) which release this would be in...
10-17-2011 06:21 PM
1. If I remember it right, CUPS doesn't work with SAN. That might have been changed on 8.5 though.
2. You may take a look at PE logs and filter out the 'owa' entries.
Michael
10-18-2011 12:43 PM
Thanks Michael,
I guess I need to raise a TAC case to check the SAN support.
I will update the thread when I get an answer.
10-27-2011 08:52 AM
James - I came across the exact same issue at a client site... TAC said that CUPS does NOT support any SAN in the server certificate...
They said that the support will be there in a future release...
Did you receive the same response from TAC?
10-27-2011 08:59 AM
Hi Joshua,
I have not actually got around to raising a TAC case yet as I have been off work.
Thanks for updating the thread with your findings - did TAC give any indication which new release will have SAN support?
James
10-27-2011 09:02 AM
11-30-2011 10:26 AM
Anybody heard anything on this issue being resolved anytime soon?
02-02-2012 07:48 AM
I am running CUPS 8.6.3 and the SAN certificate are still not supported but...Even that I have a
"SubjectCN Mismatch" on the Exchange Presence Gateway the access to the calendar is working.
I have also found that it will be supported in 8.6.4 (date ??) in the CUPS Integration Guide for Exchange
02-02-2012 10:52 AM
Christian,
Thank you very much for updating this thread. I will try applying the upgrade to 8.6.4 when it becomes available.
