CVP with UCCX integration
sinuksml1
can we integrate CVP with UCCX?
This is outdated as UCCX is no longer supported for integration with UCCE (it was for couple of versions).  There would be no way of integrating CVP directly with CCX.
Manish Gogna
Please check the following post with similar query
https://communities.cisco.com/thread/54572
Manish
- Do rate helpful posts -
thanks for the reply,
but i need to double confirm that
can you please check the below link,i read that,we can use ccx with cvp by using VRU type cvp deployment model.
http://products.mcisco.com/c/dam/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/customer_voice_portal/srnd/8x/cvp8xsrnd.pdf
"A typical call in this model would be pre-routed by Unified ICM to a Unified CVP Ingress Voice Gateway for call treatment and queueing. When an agent becomes available, Unified ICM instructs the PSTN to transfer the call to that agent. The agents can be Cisco Unified Contact Center Enterprise agents, Cisco Unified Contact Center Express agents, or traditional ACD agents"
is that possible?
