Cygwin for taking backup of CUCM and CUC
geeta.kumari1
Hi All,
Has anybody use Cygwin successfully as a sftp server on windows system for backing up configuration file.
Please advice.
Geeta
Deepak Rawat
You can very well use Cygwin as it is one of the supported SFTP servers recommended by Cisco to take DRS backups of UC applications. Refer below:
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/drs/10_0_1/CUCM_BK_D220A91D_00_disaster-recovery-system-cucm-100.pdf
Deepak
Hi Deepak,
I tried using Cygwin and configured the ssh but however the sftp authentication is failing. Do you have the CLI commands for Cygwin ?
Geeta
Check this
https://supportforums.cisco.com/document/63001/setup-cygwin-openssh-drs
Manish
Hi Manish,
I did checked your documentation before and followed step as per it, however, I keep getting " permission denied, Please try again later" message even when checking the ssh connection locally. Can you help me with some more detail to resolve this. Is anyone was able to use it successfully  over windows 2008R2 / windows 7 ?
