08-14-2017 04:42 PM - edited 03-19-2019 12:43 PM
All,
I need to decommission a particular node that is in a data center that is going away. What all do I have to check before powering down the node?
This is an 8 node cluster that is going away altogether. There are about 400 registered phones left. The cluster has been up for 7 or so years and not every change has been documented. Thus, it is a little difficult to remember what all it is being used for. Checking dependencies only gives you a small idea, but I want to make sure that when I power down the server no services are disrupted.
Thank you for your suggestions!
Solved! Go to Solution.
08-15-2017 04:41 AM
Your answer will be covered i guess in the below thread.
https://supportforums.cisco.com/discussion/12956056/deleting-server-node-cucm-cluster
Please note that you have to reboot the whole cluster to update the cluster after removing the node. Also please do a proper check for things specific to the node like call park number etc.
We are also doing almost same thing for one of our customer with a 8 node cluster running on 8.6 and upgrading to 10.5 due to some requirements.
Alok
08-15-2017 04:41 AM
Alok
08-17-2017 08:50 AM
Thanks much Alok!
