Detailed Sip message not showing on RTMT
akramroot
Hello all,
I have a cucm pub and sub v 14 , i have a problem the detailed sip message not showing on RTMT .
I checked  Sip call processing trace  is enabled , and the debug trace level is set to state : detailed on the pub and sub .
You can find below the images captured
Could you help me please
Best reagrds
Make sure it is enabled on all nodes, and ensure the logs you are trying to capture are from the call processing node.
Response Signature
Hi Nithin, thank you for your reply ,
Yes , the Enable SIP Call Processing Trace  si enabled on all nodes (pub , and sub)
The logs i'm  trying to capture is from the call processing node.
Best regards
