Dial Peer Regex question
cheryl.alvarado
I'm having a little trouble wrapping my head around dial peer regex matching, and hoping somebody here is up for a challenge.
I am wanting a single dial peer for all of our inbound calls from our provider.
I currently am matching:
incoming called-number 620555[1-6]...$
However, that's matching too many numbers.  What I need is a regex that will match all of these:
6205551200
6205554[012456789]..$
620555[5-6]...$
How can I combine all of these into a single regex?  Or am I doomed to multiple dial-peers?
Jaime Valencia
Best you could do is 620555[1456]...$
No way for a single regex to match only what you're matching with those 3 individual regex.
java
if this helps, please rate
620555 1200
620555 [456]...
The first one u  make an exact match.
Response Signature
What type of dial peer is this for? If it’s a voip dial peer you have a few more options. Have a look at this excellent document. https://www.cisco.com/c/en/us/support/docs/voice/ip-telephony-voice-over-ip-voip/211306-In-Depth-Explanation-of-Cisco-IOS-and-IO.html
Response Signature
