Difference between CUBE14-T-ENH and CUBE14-T-STD
pvogt
Hello Everyone,
can someone explain the difference between CUBE14-T-ENH and CUBE14-T-STD to me or does someone know where to find detailed explanation ? THanks in advance. Regards Petra
Thank you !
Hi Nithin... how many CUBE14-T-ENH do I need to considerate if I want a couple of ISR44310-V/K9 in HA mode? for example.. 30 simultaneously calls... I need 60? 30 per chassis...thanks.
j.a.m.e.s
Level 4
Level 4
Good question and several years on I still can't see sufficient info around the CUBE14-T-ENH licenses. I also can't find any of these part codes on the Build & Price tool. It's also not stated whether these licenses are meant to be counted as a 'concurrent call' or are as a wider count of users making calls via the CUBE. They say the reporting will be done back to the license portal on a routine basis, but exactly what metric will be reported?
Quite incredible that people are able to purchase CUBE.
