Direct Routing for Microsoft Phone System with Cisco Unified Border Element
takahashi-ta
I am using vCUBE (on CSR1000v) to build direct routing for Microsoft Teams Phone System.
ITSP is using Twilio.
In this environment, I can make and receive outgoing calls from Microsoft Teams Client to Twlio direction, but the signaling is not working well from Twilio to Microsoft Teams Client direction.
I used TranslatorX to draw a SIP ladder sequence from the results of the debug ccsip messages and found that the CUBE is not receiving any response to the INVITE it sent to the Micorosoft Teams Phone System.
The TLS connection is normally working as shown below.
(ex)
Remote-Agent:52.114.76.76, Connections-Count:3
Remote-Port Conn-Id Conn-State WriteQ-Size Local-Address TLS-Version Cipher Curve
5061 140 Established 0 x.x.x.x TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 P-384
3521 142 Established 0 x.x.x.x TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 P-256
3520 141 Established 0 x.x.x.x TLSv1.2 ECDHE-RSA-AES256-GCM-SHA384 P-256
However, the moment I make a call from Twilio to the Micorosoft Teams Client, I get the following message.
%SIP-3-INTERNAL: Connection failed for addr=52.114.76.76, port=5061, connId=140
For some reason, the TCP TLS connection seems to be failing momentarily, and I suspect this is why the signaling is not working properly.
Is there any configuration I should review?
By the way, I am referring to the following document for setting up the CUBE.
https://www.cisco.com/c/dam/en/us/solutions/collateral/enterprise/interoperability-portal/direct-routing-with-cube.pdf
47 Replies 47
rchaseling
Level 4
Level 4
Did you get this resolved?
I'm seeing the same - my dialpeer is going up and down every minute or so even though SIP Options appears to be working fine
Mar 26 17:37:41.574 GMT: %SIP-3-INTERNAL: Connection failed for addr=52.114.76.76, port=5061, connId=38
Carl Ratcliffe
Level 3
Level 3
Hi, I have successfully setup CSR1000v CUBE for Teams Direct Routing following the same guide and have inbound and outbound calls connecting with no issues using this flow -  Provider SIP > CUBE > CUCM > CUBE Direct Routing > Teams.
The message " Mar 26 17:37:41.574 GMT: %SIP-3-INTERNAL: Connection failed for addr=52.114.76.76, port=5061, connId=38" is possibly a red herring as I was also getting the same message all the time when connected to the CLI even when not making calls along with other IP addresses and it didn't seem to affect calls.
For reference i upgraded to the latest version and don't seem to get the error anymore - csr1000v-universalk9.17.03.03.SPA.bin
Thanks, Carl Ratcliffe
Thanks.
I don't going its a red herring though as I see the socket close and the dialpeer goes down (options ping) so it might failover to other Microsoft IP and still work but this is not ideal for production.
It's strange cause I'm getting replies to options ping bug then the TLS socket just closes.
I've copied the config and details from the "new" guide too.
I'll do some more testing and revert
I actually have a transfer issue with Teams Direct Routing that I have posted on here however I think the troubleshooting I have done on that could be linked to your issue and maybe that IP is literally the "route" to all our problems. I don't know why yet but if you have any ideas it might be the fix for both issues.
As i mentioned Inbound / Outbound calls work no issue for me but when i request to transfer i receive the REFER then you get a really long wait time with nothing happening then the transfer will wither eventually complete ( 60 seconds plus end to end ) or fail.
When i say nothing happening the debug ccsip all and debug voip ccapi inout have nothing except responding to a few OPTIONS so this made me think is it the CUBE itself not the VoIP so first of all i took the easy way out and upgraded the IOS but it didn't fix my issue.
Next i went to the network/routing/firewall layer and all seemed fine so i took the final step of debug ip packet as i really needed to see what was happening between the REFER and the transfer seen as no voice messages were output and this is my findings.
  • The REFER message has this field and notice the IP  - VIA: SIP/2.0/TLS 52.114.76.76:5061;branch=z9hG4bK24ece8b0
  • My debug IP Packet from the REFER to the next SIP Message is littered with these and 1.2.3.4 is my interface used to Teams.
Mar 28 09:00:33.341: FIBipv4-packet-proc: route packet from GigabitEthernet1 src 52.114.76.76 dst 1.2.3.4
Mar 28 09:00:33.341: FIBfwd-proc: EURODC1-CUBE-Outside:1.2.3.4/32 receive entry
Mar 28 09:00:33.341: FIBipv4-packet-proc: packet routing failed
Mar 28 09:00:33.341: IP: tableid=3, s=52.114.76.76 (GigabitEthernet1), d=1.2.3.4 (GigabitEthernet1) nexthop=1.2.3.4, routed via RIB
So the bottom line is it can't communicate with that IP hence my transfer delay and maybe the reason for your Failed Connection however i don't think its that simple as i can communicate with that IP and this is from the same trace which indicates i can communicate ( at least some of the time ).
Mar 28 09:00:26.168: //-1/xxxxxxxxxxxx/SIP/Transport/sip_tls_tcp_handshake_proc: TLS HANDSHAKE is successful with trunk peer 52.114.76.76
Update my side (I haven't actually tsted any calls yet as waiting for Teams side to be configured)
I didn't have a DNS server avialable before so I had static host records configured on CUBE. I have since configured DNS servers and the dial-peer going up and down every minute has stopped.....but issue not completely resolved!!!
Rather than every minute it is not happening every hour..... nearly on the dot but dialpeer is not going down anymore
See screenshot of logging I've had running
Connection fails to 52.114.76.76 at 13:53 mins past the hour (but not every hour)
Connection fails to 52.114.132.46 at 02:26 past the hour (but not every hour)
Surely this is something on the microsft side but I guess could be CUBE or firewall also....
I honestly don't know but I also thought it has to be the Microsoft side especially since you posted the same IP address but at the same time the CUBE is definitely doing something weird.
As I mentioned inbound/outbound calls setup perfectly every single time and I only get the issue with a transfer ( REFER ) so you would think that setup is the issue but the CUBE does just seem to stop processing VoIP traffic so it is either a CSR1000v issue or something it receives in the REFER it doesn't like ( even though it accepts it ) but then if that was the case you would still expect to see SIP messages. It's the same every time, REFER > ACCEPT then 25-30 seconds of zero SIP messages until it eventually decides to send the NOTIFY then it will either complete the transfer or just say cant complete.
I have a ticket logged with Microsoft so will see what they come back with. I also want to log with Cisco but as its a proof of concept i only used trial CSR1000v licenses so not sure if i can log anything yet.
Keep in touch as it will be interesting to see if you get the same issue with transfer.
So I'm deployed on a pair of 4331 configure in HA so if I have the same issue as you we'll know its not a CSR1000v issue
I should hopefully get to start getting test calls in/out of the coming days. I'll ket you know
One thing I do now know is that it isn't just that IP address, at least for my issue.
I noticed that my home internet resolved to a different Microsoft Teams signaling address for sip.pstnhub.microsoft.com compared to my CUBE so i forced the CUBE to use this same DNS and it forced it to 52.114.7.24 but my issue still persists for transfers.
Hi, did you mange to test any calls yet?
I still have a transfer issue and have tickets logged with both cisco and Microsoft but no solution yet.
So basic calls are working but customer having problems getting my Teams account working so have not done any testing myself yet.
BUT I am still getting lots of disconnects that sometimes cause a dialpeer to go down. This could well be causing a problem if this was production. Have a look at logging for overnight last night! THis cannot be right! Is this similar to what you are seeing?
Definitely something not right especially with them being at regular intervals.
Although not ideal, users may not notice any issue as they are signaling addresses not media so connected calls should not be affected and on the off chance it happened during call setup it should just use another dial-peer after a slight delay.
Not long after I wrote the previous update I got a fix / workaround for my call transfers issue and it was relating to this bug and the fix is to basically block REFER and force Microsoft to use re-INITE although Microsoft say this isn't possible or supported with Teams but it certainly works for me so if you do have issues with transfer try this.
In typical Microsoft / Cisco rivalry Cisco are quick to point out the issue is not the CUBE but I'm not sure if that is strictly true because just receiving that REFER seems to completely lock up voice services on the CUBE  and I'm not sure Microsoft could be at fault with that.
" The race condition is on the peer device and not CUBE, which falls outside of the CUBE control. REFER/BYE scenarios like this are in accordance to RFC 5589."
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvv13018/?rfs=iqvred
Very interesting and noted!
Just to finish this off - are you still seeing the same connection failure messages but everything is working fine?
Yes I am and like yours there is a definite pattern.
I haven't noticed any issues but we are in proof of concept so only have limited users so that isn't to say it isn't causing an issue.
Apr 3 10:12:30.716: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=6657, connId=841
Apr 3 10:34:45.817: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=8512, connId=842
Apr 3 11:35:20.652: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=1281, connId=843
Apr 3 12:12:30.716: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=6656, connId=844
Apr 3 12:34:45.817: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=8513, connId=845
Apr 3 13:35:20.652: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=1280, connId=846
Apr 3 14:12:30.716: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=6657, connId=847
Apr 3 14:34:45.817: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=8512, connId=848
Apr 3 15:35:20.653: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=1281, connId=849
Apr 3 16:12:30.716: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=6656, connId=850
Apr 3 16:34:45.818: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=8513, connId=851
Apr 3 17:35:20.654: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=1280, connId=852
Apr 3 18:12:30.716: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=6657, connId=853
Apr 3 18:34:45.818: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=8512, connId=854
Apr 3 19:35:20.655: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=1281, connId=855
Apr 3 20:12:30.716: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=6656, connId=856
Apr 3 20:34:45.818: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=8513, connId=857
Apr 3 21:35:20.655: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=1280, connId=858
Apr 3 22:12:30.716: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=6657, connId=859
Apr 3 22:34:45.819: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=8512, connId=860
Apr 3 23:35:20.655: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=1281, connId=861
Apr 4 00:12:30.716: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=6656, connId=862
Apr 4 00:34:45.819: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=8513, connId=863
Apr 4 01:35:20.655: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=1280, connId=864
Apr 4 02:12:30.717: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=6657, connId=865
Apr 4 02:34:45.819: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=8512, connId=866
Apr 4 03:35:20.656: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=1281, connId=867
Apr 4 04:12:30.717: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=6656, connId=868
Apr 4 04:24:42.582: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=6152, connId=342
Apr 4 04:25:22.550: %SIP-3-INTERNAL: Connection successful for addr=52.114.75.24, port=5061, connId=872
Apr 4 04:30:54.251: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=5061, connId=400
Apr 4 04:31:38.009: %SIP-3-INTERNAL: Connection successful for addr=52.114.7.24, port=5061, connId=875
Apr 4 04:34:45.819: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=8513, connId=869
Apr 4 04:37:38.400: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=5061, connId=872
Apr 4 04:37:44.775: %SIP-3-INTERNAL: Connection successful for addr=52.114.75.24, port=5061, connId=879
Apr 4 04:47:03.040: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=10368, connId=873
Apr 4 05:02:23.221: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=1280, connId=870
Apr 4 05:18:02.927: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=5061, connId=879
Apr 4 05:18:08.792: %SIP-3-INTERNAL: Connection successful for addr=52.114.75.24, port=5061, connId=882
Apr 4 05:24:41.082: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=7168, connId=876
Apr 4 05:25:02.470: %SIP-3-INTERNAL: Connection successful for addr=52.114.7.24, port=5061, connId=885
Apr 4 05:33:44.678: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=5061, connId=419
Apr 4 05:34:32.282: %SIP-3-INTERNAL: Connection successful for addr=52.114.132.46, port=5061, connId=888
Apr 4 05:45:27.002: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=5061, connId=885
Apr 4 05:46:11.425: %SIP-3-INTERNAL: Connection successful for addr=52.114.7.24, port=5061, connId=891
Apr 4 05:46:33.253: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=2304, connId=886
Apr 4 05:46:34.514: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=2305, connId=887
Apr 4 06:05:31.219: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=8256, connId=420
Apr 4 06:12:30.718: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=7177, connId=881
Apr 4 06:27:37.756: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=5061, connId=891
Apr 4 06:28:28.822: %SIP-3-INTERNAL: Connection successful for addr=52.114.7.24, port=5061, connId=894
Apr 4 06:40:30.312: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=5061, connId=882
Apr 4 06:40:32.973: %SIP-3-INTERNAL: Connection successful for addr=52.114.75.24, port=5061, connId=897
Apr 4 06:48:01.366: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=5061, connId=888
Apr 4 06:48:59.202: %SIP-3-INTERNAL: Connection successful for addr=52.114.132.46, port=5061, connId=898
Apr 4 07:12:30.718: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=7176, connId=880
Apr 4 07:35:20.657: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=1088, connId=892
Apr 4 07:39:30.338: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=5061, connId=898
Apr 4 07:40:14.246: %SIP-3-INTERNAL: Connection successful for addr=52.114.132.46, port=5061, connId=903
Apr 4 08:34:45.819: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=3201, connId=900
Apr 4 09:12:30.719: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1218, connId=901
Apr 4 09:34:45.820: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=9793, connId=905
Apr 4 09:35:20.657: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=5066, connId=902
Apr 4 11:12:30.719: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1024, connId=906
Apr 4 11:34:45.821: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1088, connId=907
Apr 4 11:35:20.657: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4416, connId=908
Apr 4 13:12:30.720: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1217, connId=909
Apr 4 13:34:45.822: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1089, connId=910
Apr 4 13:35:20.658: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4417, connId=911
Apr 4 15:12:30.720: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1344, connId=912
Apr 4 15:34:45.822: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1088, connId=913
Apr 4 15:35:20.658: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4416, connId=914
Apr 4 17:12:30.720: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1536, connId=915
Apr 4 17:34:45.822: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1089, connId=916
Apr 4 17:35:20.658: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4417, connId=917
Apr 4 19:12:30.720: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1537, connId=918
Apr 4 19:34:45.823: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1088, connId=919
Apr 4 19:35:20.658: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4416, connId=920
Apr 4 21:12:30.721: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1217, connId=921
Apr 4 21:34:45.823: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1089, connId=922
Apr 4 21:35:20.659: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4417, connId=923
Apr 4 23:12:30.721: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1218, connId=924
Apr 4 23:34:45.823: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1088, connId=925
Apr 4 23:35:20.660: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4416, connId=926
Apr 5 01:12:30.721: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1217, connId=927
Apr 5 01:34:45.823: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1089, connId=928
Apr 5 01:35:20.660: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4417, connId=929
Apr 5 03:12:30.721: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1218, connId=930
Apr 5 03:34:45.824: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1088, connId=931
Apr 5 03:35:20.660: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4416, connId=932
Apr 5 05:12:30.721: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1217, connId=933
Apr 5 05:34:45.825: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1089, connId=934
Apr 5 05:35:20.660: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4417, connId=935
Apr 5 07:12:30.721: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1218, connId=936
Apr 5 07:34:45.826: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1088, connId=937
Apr 5 07:35:20.660: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4416, connId=938
Apr 5 09:12:30.721: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1217, connId=939
Apr 5 09:34:45.826: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1089, connId=941
Apr 5 09:35:20.660: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4417, connId=940
Apr 5 11:12:30.722: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1344, connId=942
Apr 5 11:34:45.826: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1088, connId=943
Apr 5 11:35:20.660: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4416, connId=944
Apr 5 13:12:30.722: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1345, connId=945
Apr 5 13:34:45.826: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1089, connId=946
Apr 5 13:35:20.660: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4417, connId=947
Apr 5 15:12:30.722: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1344, connId=948
Apr 5 15:34:45.827: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1024, connId=949
Apr 5 15:35:20.660: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4416, connId=950
Apr 5 17:12:30.722: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1217, connId=951
Apr 5 17:34:45.828: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1025, connId=952
Apr 5 17:35:20.660: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4417, connId=953
Apr 5 19:12:30.723: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1218, connId=954
Apr 5 19:34:45.828: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1088, connId=955
Apr 5 19:35:20.660: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4416, connId=956
Apr 5 21:12:30.723: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1217, connId=957
Apr 5 21:34:45.828: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1089, connId=958
Apr 5 21:35:20.660: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4417, connId=959
Apr 5 23:12:30.723: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1218, connId=960
Apr 5 23:34:45.829: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1984, connId=961
Apr 5 23:35:20.661: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4416, connId=962
Apr 6 01:12:30.723: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1217, connId=963
Apr 6 01:34:45.830: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1024, connId=964
Apr 6 01:35:20.661: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4417, connId=965
Apr 6 03:12:30.724: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1218, connId=966
Apr 6 03:34:45.830: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1984, connId=967
Apr 6 03:35:20.661: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4672, connId=968
Apr 6 05:12:30.724: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1217, connId=969
Apr 6 05:34:45.830: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1985, connId=970
Apr 6 05:35:20.661: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4673, connId=971
Apr 6 07:12:30.724: %SIP-3-INTERNAL: Connection failed for addr=52.114.75.24, port=1218, connId=972
Apr 6 07:34:45.830: %SIP-3-INTERNAL: Connection failed for addr=52.114.132.46, port=1984, connId=973
Apr 6 07:35:20.661: %SIP-3-INTERNAL: Connection failed for addr=52.114.7.24, port=4672, connId=974
Scott Leport
Level 7
Level 7
Hey Guys,
Sorry to hijack this thread. Been following it with interest on and off lets say.
A few quick questions, just to see what "sticks":
1. Is your IP routing towards the MS Teams SIP proxies, media servers and the DNS servers from the guide going out the same path?
2. Do you have SIP ALG disabled on your upstream Firewalls or ALG disabled from your CUBE if it's the Internet gateway?
3. Is your SIP signalling and media both bound to the correct interfaces?
4. Random one, have either of you tried disabling CRL checking on the Baltimore cert? I had a weird issue where I couldn't get the trunk up between CUBE and Teams and that was the fix for me. May not be either of your issues here and to be honest, you'd probably see something in the logs regarding a CRL checking issue, but figured I'd ask!
