Document existing configuration
gdelement
I am new to an organization and part of my responsibilities will be administrating the existing cucm solution. Is there a away of documenting the existing configuration and settings without going from screen to screen?
Chris Deren
There are tools that you can purchase that will do just that, one of them that is pretty good it uplinx:
http://www.uplinx.com/reporttool.htm
HTH,
Chris
Rob Huffman
Hi Gary,
In addition to the great info from my buddy Chris (+5 sir )
Have a look at Variphy, it does offer great reporting, a very granular level
of CUCM change audit tracking, plus an excellent "snapshot" feature.
http://variphy.com/products/enterprises/cisco-configuration-reporting
Cheers!
Rob
"Talk about a dream
Try to make it real"
- Springsteen
Thanks Rob, +5 right back at you for another good option.
Chris
