does it required to renew CUCM CUWL and Enhanced License
we have CUCM System version: 11.5.1.12900-21 previously it was version 10.5 now its 11.5 upgraded license installed i want to know does it required to renew licenses under SMART NET or its on permanent basis and why my devices are using enhance license why not CUWL license as shown in attached???
5 Replies 5
Enhanced licenses are assigned when there is either no user associated with a device, or if a user is assigned to only one or two devices. Once you hit three, the license is pulled from CUWL. So it may be that your users have only one or two devices assigned or that you have not yet assigned users to devices.
If your users are only assigned one or two devices, this is CUCM trying to use the 'lowest' license possible to have a user in compliance. You will notice that while they are assigned an Enhanced License, the ELM pulled the license from the CUWL bucket.
So if your users are not associated with devices, do that. If they are associated with devices, you can see who is associated with what in the license menu in CUCM. In CUCM you will see the difference types of licenses and a link to the usage. If you click on the link you will see the users who are using a particular type of license, and you will also see any devices not associated with a user.
Maren
Thank your for your reply its really easy to understand the way you write. just a small question
does it required to renew on yearly basis ??? and is there any relation SMART NET and license renewal???
Device/User licenses like CUWL/Enhanced are permanent.
SMARTNet is a contract and does have to be renewed periodically. Check with your Cisco account rep on your options there. In addition to SMARTNet on gear, there is another variety of service contract on software (like CUCM) that allows upgrades as well. I am not well-versed in this area, but your account rep should be able to explain it. Or perhaps someone else on this forum can chime in.
Maren
Hello Maren,
kindly advise why Cisco Jabber license should be renewed yearly ?
There is no need to renew your endpoint licenses if you still have perpetual licenses. All currently sold licenses are apart of the FLEX program, so they are subscription based. However with both the older and newer licensing schemes there is the part of support options that needs to be renewed at the time of expiration. This could be annual or longer time frame. The support part gives you the right to upgrade your system to a later major version and get support from TAC.
Response Signature
