DRS issues with Unity Connection 7.1.5
Alex Bagaglio
Hi all,
We're having some Issues with the DRS Backup of a CUCM BE 7.1.5 System.
System Version is 7.1.5.10000-12.
When selecting the CUC Feature in DRS the backup fails,
The Error I get is the following:
Failed to initiate backup. Server [ZURCM01], component [CLM] requires component [PLATFORM] to be registered.
When deactivating the CUC Feature the Backup runs normally.
Any ideas how to fix this?
Thanks for all your Help
BR
Alex
Brad Magnani
Hi Alex,
You may want to try the steps in the below defect and see if it helps you any:
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsw64366
Hope that helps,
Brad
Brad Magnani
Hi Alex,
Hope that helps,
Brad
Hi Brad,
Thanks for your Help.
The Solution was to Re-create the ipsec Cert.
CUC now gets backed up correctly!
Thanks again
Alex
Great! Glad it worked.
Brad
