Error during upgrading Cisco Unity Connection to SU2
ryabutler
Help!
I'm facing an error while upgrading Cisco Unity Connection 8.5.1.10000-26 to SU2 (8.5.1.12900-7).
When it's trying to download the SU2 file (UCSInstall_UCOS_8.5.1.12900-7.sgn.iso ) to Unity Connection after 2GB I get this error:
Error encountered: Upgrade has detected that the ISO file name has been changed from the original name. This is not allowed. MD5 Hash Value: 32:32:db:47:99:48:c6:53:12:e2:78:76:94:90:a4:1d
I tried this from multlpe FTP servers and I downloaded the SU2 file multlpe times assuming the download was bad.  I also rebooted the Unity Connection server here and there assuming it was something with the server.
I first tried SU1, but that gave the same error, so I attempted to go with SU2.
Any ideas for resolving this?
Thank you!
-rya
6 Replies 6
Chris Deren
The upgrade shoould be over 4 GB, are you downloading it directly from CCO download page?
Chris
Rob Huffman
Hi Rya,
Something is wrong with the file. Here's the MD5 that shows on your error
your md5
here's the actual md5 shown on the download page for UCSInstall_UCOS_8.5.1.12900-7.sgn.iso
MD5 Checksum:    26289d2f3074a2880aaf4102d8aeadc3
Maybe try the download from a different PC/connection
Cheers!
Rob
"Show a little faith, there's magic in the night" - Springsteen
I did a lot of that.  I tried to re-download multlple times from multlpe different computers.
I knew it was a MDD5 hash mismatch because the readme file for that image was different.  But I assumed it was something else since I downloaded the file 4 times already from different computers and the same problem occured.
And yes, the file size is 4GB, but the downloading process to Unity Connection stops around 2GB.
Thank you!
-rya
Rob Huffman
Hi Rya,
OK...well you've certainly done your due diligence here
Did you run an MD5 check after the download to compare the file values?
I had a long look for bugs related to this issue and came up empty so I can't see
a bug being the cause of the issues here. Is it possible for you to try "burning" the
upgrade .iso to a DVD and trying again?
I am also curious why you wouldn't move straight to 8.5(1)SU4
Cheers!
Rob
Hi Rob,
The issue was resolved when we used SFTP instead of FTP.
Not sure why, but it worked.
Thanks for the sticking through this with me.  (+5 rewarded)
-rya
Hi All,
Me too faced same issue since file corrupted, got resolved by using new file.
Thanks and Regards
Sajid Pasha Muhammad
