Expressway E and C TLS connection failed
asmlicense
Hello Cisco world,
I am trying to build a connection between E and C, but the sip connection fails. Corporate has internal (ex. test.local) and external (ex. test.com) domain. And according to domains, internal and external DNS. I also have Microsoft CA.
Expressway C hostname: expc.test.com
Expressway E hostname: expe.test.com
Trusted CA certificates are valid in both E and C with test.local.
in Generate CSR for EXPe, I include only "Unified CM registrations domains" as test.com.
in Generate CSR for EXPc, I include nothing. There is just FQDN.
I can upload server sertificates certificates successfully, but tls connection is not active.
Manish Gogna
Can you verify the certificate requirements as per the following guide ( page 15 onwards )
http://www.cisco.com/c/dam/en/us/td/docs/telepresence/infrastructure/vcs/config_guide/X8-5/Mobile-Remote-Access-via-VCS-Deployment-Guide-X8-5-1.pdf
Manish
I have gone through the official document of expressway 8.6. It was almost the same which you suggested.
asmlicense
By the way, OpenSSL works.
