Extension Mobility questions
David Graham
I am trying to setup Extension Mobility for all users. It works well, but I have some questions to hopefully make it easier before I roll it out.
1. Our Login IDs are the users 4-digit extension. When logging in to EM we and typing in the ID we have to hit the button 4 times (just like texting) to get to the number. Is there any way to make this only numeric and not alphanumeric?
2. Is there anyway to allow a user to force off another EM session? For example, I log into EM on a phone in one building. I forget to log off before I go to another building. When I try logging in at the other building I get an error "Login Unsuccessful". Can I instead have it tell me that I am logged in elsewhere and ask if I would like to force the other logon off? I can see this happening a lot with our VPs who go between offices and would like to make this easy for them to do.
Thanks much for all answers. This is pretty cool if I can get these kinks worked out.
Cheers!
Dave
Jaime Valencia
Change these EM service parameters
This parameter specifies the behavior for multiple attempted logins  by the same user on different devices within the same cluster. Allowed  values are : 1. Multiple Logins Allowed (the same user ID can be logged  in to extension mobility on more than one device), 2. Multiple Logins  Not Allowed (a user ID can only be logged into one device) and 3. Auto  Logout (if a user ID is logged into extension mobility on one device,  and the same user ID attempts to login to extension mobility on a  different device, the first device automatically logs out). For EM Cross  Cluster, multiple login is always allowed.
   This is a required field.
   Default:                  Multiple Logins Not Allowed
This parameter specifies whether the user ID to be used is  alphanumeric or numeric. Valid values specify True (user ID is  alphanumeric) or False (user ID is numeric).
   Default:                  True
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
Jaime Valencia
   Default:                  True
java
java
This was perfect. Did not log into this area before. Thanks much for the help!
Dave
David,
a SSO for EM can be a solution for your users. check alm - active login manager. search using google
