Fax machines CUCM
ziqex
Level 4
Level 4
I would like to upgrade VG 224s next week. As their is the requirement to test fax machines after the upgrade I would like to find out which VG is configured for which fax machines within the office.
I could not find anything in the VG running config. I was advised to get the info from cucm.
What would be the easiest way to locate the fax machine and their respective VG?
I don't know what device type are those fax machine in remote office so cannot search by device type in CUCM.
Any suggestions would be highly appreciated.
Thank you.
Daniel
Look at Gateways in CUCM. On the VGs it will have a list of assigned devices.
Response Signature
