08-11-2020 03:12 AM
forwarded calls gets disconnected. ISP asking us to check configuration.
Solved! Go to Solution.
08-11-2020 04:20 AM
are you using PRI ?
if yes, can you share the output of "debug isdn q931"
on gateway check Calling Party Selection. if its originator, change it to First or last redirect number and check if it works.
08-11-2020 04:20 AM
are you using PRI ?
08-11-2020 06:49 AM
First Redirect Number resolved the issue.
