12-17-2020 08:44 PM
Just did a fresh install of 10.5.2 and upgraded to SU2a. I'm able to add a SFTP server for backups, but when I go to either backup the Publisher or try to run a restore of a backup that was taken from a previous install I'm getting this:
Unable to process request, master agent is busy
I've tried restarting DRS services but that hasn't helped. I also did a 2nd fresh install after downloading the SU2a file a 2nd time and had the same issue. Just want to see what I might be looking at in terms of reasons.
Solved! Go to Solution.
12-17-2020 10:13 PM
Can you make sure the services are up and running from CLI.
show services list page
12-17-2020 10:13 PM
12-18-2020 09:29 PM
Thanks for this. I guess in the attempt to get it online quickly I forgot to start all the services. Once I did that it came up w/o any issues. Thanks.
